Where is the pilot light located… I took the shield off in the oven, can’t seem to find where the pilot light is… Oven is not working, when I turn the oven on, after a few minutes I smell gas. HELP!!!
Lori,
I don’t think you have a pilot light,
You most likely have an ignition system (glow bar), and it’s probabbly weak,
A model number would be a great help, in our attempt to asisst you.
Since you’ve already removed the oven bottom / shield, and looked around, did you see something that looks like this, mounted to the side of the bake burner tube ?
A model number would really help , a lot.
Thanks,
