I have a whirlpool gold gas range. We recently had a power outage and when the power returned the display puts out “PF”. We have tried to reset it by pushing cancel and the display does not respond. We tried unplugging from power for about an hour and still same results. The burners work fine but the controls on the display for the oven do not.
I ordered PT11333307 (9760013) Electronic control and when I installed it and gave power back to the range I still see the same “PF” on the display.
HELP!
Whirlpool Gold Gas Range Oven
Model: GW395LEPS01
Thanks,
Jaime
[quote=jld1969;114576]i have a whirlpool gold gas range. we recently had a power outage and when the power returned the display puts out “pf”. we have tried to reset it by pushing cancel and the display does not respond. we tried unplugging from power for about an hour and still same results. the burners work fine but the controls on the display for the oven do not.
[/color]
[color=#000000]i ordered pt11333307 (9760013) electronic control and when i installed it and gave power back to the range i still see the same “pf” on the display.
[/color]
[color=#000000]help!
[/color]
[color=#000000]whirlpool gold gas range oven
model: gw395leps01
[/color]
[color=#000000]thanks,
jaime[/quote]
if you replaced the control board, and you still have the pf on the control, it has to be the touch pad, the part you touch. now that touch pad comes only with the whole control panel. tom
did that fix it ..??
I Have The Same Problem On My Whirpool Gold Gas Range That I Bought 4 Years Ago. Pf Code Reading, Clock Is On, But None Of The Buttons Work. I Want To Know If Changing The Control Board Is Difficult And Does It Require Alot Of Wiring? PART NUMBER 9760013.HELP
