Personality code needed
Brand:ge
Model Number:jb645rk4ss
Main Symptom: Need personality code to set up new control board
What happens & when: personality list in the package does not have one to match our original of wb27x29092. ge says it was replaced by wb27x45466
Parts or tests already tried: bought part wb27k10357 from you.
Hi there! I was able to verify the correct personality setting for your GE range.
GE JB645RK4SS
Personality Code: 164
Original control: WB27X29092
Replacement control: WB27X45466
How to program the new control
  1. Turn on power to the range. The new control should automatically enter programming mode.
  2. Use the UP/DOWN arrow buttons to select 164.
  3. Press and hold START for approximately 2 seconds.
  4. The control should reboot and save the setting.
If you’ve already entered a different code, disconnect power and restore it. Within 5 minutes, press and hold START + UP together for 2 seconds to access the personality setting again.
One important note: If code 164 isn’t available when scrolling through the settings, don’t select another code. That could indicate an incorrect replacement board or a programming issue.
Once programmed, test Bake and Broil to make sure both operate correctly.
