Permanent removal of ice maker from Whirlpool
Have tried removing ice maker, but compressor won’t run afterwards. Does the connector (fridge side) need a jumper plug?
Replacement parts for ET16JMXL models | AppliancePartsPros.com
Looks like the icemaker includes the defrost thermostat so you are stuck with it.
ET16JM.pdf (242.6 KB)
Thanks for the help. If I had that spec sheet, I would’ve figured it out. Thanks again!:smiley:
