Peb
low temp not working. high temp heats normally
Not working as in no heat at all when a low temp cycle is ran?
no heat at all when low cycle is run
I’m going to test high limit thermostat and the low temp switch for continuity first
If your hi limit was open it wouldn’t heat at all. No harm in testing it of course, But the temp switch is a likely suspect.
