:eek: I have a Maytag Dryer model lde8600acw. When in use it rumbles and growles some times… you can hear the dryer basket slow down then speed up it heats up fine and actually still dryes at about 90%. how do i fix this please help
Well, my semi-educated guess (since I am not there to hear it, which is the main way we diagnose these problems) is that your rollers are worn out. Here is the part
and here is a service manual which will tell you how to get to them and replace them. Not a difficult job, just time consuming so be patient and go slow. Check the front of the drum when you take it out to make sure there is not problem at the end also.
http://www.servicematters.com/maytag_library/docs/16008714.pdf
