Brand: Samsung
Model Number: WF42H5200AF/A2
Main Symptom: code 66:66, cycling lights, unable to select options
What happens & when: washer would not spin hard enough to remove enough water to dry clothes. Washer reached down to 6 minutes left to finish and would then flip back to 10 minutes left to finish and would run more water. Would continue you this cycle without completing. Changed the shocks and PCB board. After connecting the new board it displays 66:66 and the lights cycle through the board and I am unable to select an option.
Error Code (if any): 66:66
Parts or tests already tried: new PCB board
