PC Board Kit
I had a repair man come to see what was the issue with the icemaker andit needs a new PC Board Kit. Would I be able to install this part myself? What is involved with the replacement - just a matter of plugging it in or does it need some wiring that is invlovedin changing the PC Board? I am divorced and can only afford to do this myself so I appreciate any help I can get with this matter.:frowning: :slight_smile:
Hello jcz. These are not hard to change. Unplug the unit and open the freezer door. Remove the screws holding the covers and the board in place. Pull the cover and board out of the wall and unplug the wire harness. Remove the screws holding the control board to the cover. Reinstall with the new parts in reverse order. Make sure you get the wire harness plugged to the control board correctly. Hope this helps.
AP5956767
Freezer liner replacement parts for WHIRLPOOL KSRS25IHWH02 SIDE-BY-SIDE REFRIGERATOR | AppliancePartsPros.com
After being sent a 2nd PC Board Kit thinking the first could be a bad part, the icemaker is still not working. The LED light is flashing blink blink, pause, blink blink, pause!!! Now what?!?!:mad: Kitchen Aid Model # KSRS25IHWH02 Serial # SK 4350848. I recvd part number WPL 4389102 order # 1992218. Do I have the right part???
Hello jcz. Here is a link to a previous post to help you with the repair. Hope this helps.
http://forum.appliancepartspros.com/refrigerator-freezer-repair/29618-ice-maker-not-working-kitchenaid.html
