Timer reaches the spin cycle the stops and does not fill with water.
Hi.
Please clarify:
The washer fills, agitates,drains, spins and do not fill during the rinse?
Simon.
Simon,Yes that is the sequence. It stops just short of filling on the spin cycle.
Chuck H
I said stp[s befpre tje spin cycle, I meant rinse cycle.
Hi.
Check the water temp settings. Usually the rinse is cold water only, so check if the cold water setting works during the wash cycle, cold water faucet, hose, solenoid valve.
Here are the breakdown diagrams and 02-Cabinet parts for Maytag PAVT234AWW - AppliancePartsPros.com
Simon.
Is the solenoid part of the "Water inlet Valve Assembly?
Yes, it is.
Simon.
