Partially functional control panel and sprayer does not work
On this model, the only the heavy wash, normal wash and rinse buttons are selectable. The control board was recently replaced and the results have not changed. In addition, the water spray arms do not work. The tub fills with water at the correct level and the temperature is correct. The buttons that do work, cycle correctly, except the spray arms. Are there multiple problems with the dishwasher or, are they directly related to each other?
First I would remove the door’s inner panel and check that rinse aid has not been leaking down onto the wires.
This unit may have been part of a recall back in 2007
https://repair.maytag.com/repair/dishwasher.jsp?siteCd=MT_EN_US
Replacement parts for mdb9600 models | AppliancePartsPros.com
Here is a manual
http://www.servicematters.com/maytag_library/docs/16021814.pdf
And the tech sheet
http://www.servicematters.com/maytag_library/docs/16026390.pdf
This may help you troubleshoot
http://www.servicematters.com/maytag_library/docs/TDD-0008-S.pdf
Check the control panel (keypad) with a meter, see the tech sheet.
Try running diagnostics.
You may want to try the following cleaning procedure.
It is hard to say if the problems are interrelated.
Not sure how you get it to start as you said only 3 of the buttons are operational.
Also you said that the spray arms do not rotate but did not say if the main motor is running.
If motor is not running check to see if it is getting voltage.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
Replaced the control board. Ran the manual function test. It indicated that the vent wax motor and the water valve were bad and that the motor was good. Would the malfunction of the water valve cause the spray arms to not receive water? I ask this because in the wash cycle, the bottom of the tub fills with water and stops at the correct level.
Gettting back to the new control board, the ‘Sales flow demo mode’ did not work when trying to activate it.
Also, the auto clean as well as the light wash indicators could not be selected when depressing the membrane, yet during the manual function test they did light up and function as the test indicated.
