Will not start…place time in any position and can hear timer running, but when I press the start button nothing happens…was working just fine the previous load…could it be that switch/pts relay ? WQould like advice before blindly ordering parts . Thanks
Replacement parts for WHIRLPOOL LEC8858EQ0 ELECTRIC DRYER | AppliancePartsPros.com
See the attachment for the wiring diagram.
At the top of my list would be the thermal fuse (Item 7 in Section 3)
Unplug the unit and check the fuse with a meter should be 0 ohms.
Jiggery Pokery method is.
Unplug the unit.
Remove both wires from the fuse, short them together and tape them up so they will not short to the frame.
Plug the unit in and give it a try.
If blown, replace the fuse ASAP as it is a critical safety device re: prevents lint fires which can turn into house fires.
Also clean/check your vent system and the blower as these are the most common causes of it blowing.
- When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
Wiring Sheet - 3401725.pdf (43.0 KB)
