Dishwasher Model #GU1200 XTLS1. After reading blogs I thought replacing the Electronic Control Assembly (#AP3775964) would work but having done that the problem still exists. Can you help?
on the front panel the following lights bling: Delay Start hour 4, Normal Wash Cycle & Cancel
In such situation the problem most likely is a bad key panel which is a part of the console. A bad control board can cause it too but it happens very seldom.
If you need the correct part number for the console, post the color of it.
Thanks for your reply. The panel black and I suspect the part number appears to be AP3176980 - if that is correct I will order one. Please let me know.
