Overheated in Jacksonville
Hi Super Techs,
 This is probably a no brainer but I have a gas range and the oven doesn't
regulate the oven temperature correctly. No matter what it is set at, the temperature skyrockets to 500 degrees or higher. I am assuming the thermostat is the culprit part # AP2623073. I would like to confirm this before I spend 85.74. Please respond and confirm this is correct.
                                       Thank you in advance
                                         Steven Hartwig
Steven,
You are absolutely right. The new thermostat should solve the problem.
Here are the break down diagrams and Replacement parts for GE JGBS23CEH3CC | AppliancePartsPros.com
