Oven
When you put the oven on Bake it will not heat over 200 degrees. Before when you go to bake it would automatically show 350 Degrees. But doesnt do that anymore at all.The element works fine on broil.
Remove the oven floor and inspect the Bake heating element.
If there is no visible damages then pull the range out of the wall, remove the rear panel and inspect the wires to the heating element.
Remove the wires from the heating element and check the element for continuity.
Check for 240 VAC between the heating element wires while the control calls for Bake.
Post the results.
Here are the breakdown diagrams and Replacement parts for MAYTAG PER5750LAW | AppliancePartsPros.com
Yes thank you the element is bad
The Bake element [PART]AP4101290[/PART]
Thank you gene for your help, I am going to try and pick one up local at ************** appliance in tampa. If i need to order i will have you order it for me.
