I went to use my oven a couple of days ago. I pushed the button to turn it on and immediately heard a “bzzt” noise (electronic shorting sound) come from the vicinity of the clock/control panel. The screen then went out and I am unable to turn on the oven. The interior light and stovetop, however, are still functional. I am trying to determine which part I need to repair this problem a) Oven Control Board #316101008, b) Relay #316113700 or Circuit Board #318111400. Or maybe it is something else altogether ??
Hi.
If you feel comfortable to run voltage test using the multimeter then :
-unplug the range
-get access to the control board/oven clock
-remove the wire from DLB contact and make sure it’s not touching any metal surface
-plug in the range
-check for 120VAC between L1 and N
-if there is a proper voltage then the control board is bad
And that’s where the problem starts. The clock/control board is no longer available.
Simon.
Thank you for your help Simon !
You are welcome.
Simon.
