Brand:frigidaire
Model Number:plgs389ecf
Main Symptom:oven won’t start
Parts or tests already tried:bi-metal gas valve
Brand:frigidaire
When you say that the oven won’t start, can you set the unit to bake and it shows that it is supposed to start but won’t lite. If this is the case, then check to see if the igniter is coming on. If it is then test at the oven safety valve to make sure that there is 3.2 to 3.6 Vac at the valve. If there is not proper power then replace the igniter.
