My Jenn-Air oven won’t move past 100 Degrees on Preheat Bake and takes a LONG Time (Hours, if ever) for Preheating on Convect Bake.
The Broiler is working. Is it possible this is the Igniter, Oven Temperature Sensor, or Electronic Control?
Any Help is Greatly Appreciated!
Hi, Linda.
I want you to open the oven door while the oven is in the bake preheat and if the bake ignitor is glowing but the gas is not lit, you need to replace the ignitor.
The bake ignitor AP6011349
When replacing the ignitor put a couple drops of water on each mounting screw - it will make a world of difference when removing the screws.
Here are the breakdown diagrams and parts list for your range:
[MODEL]JGR8875RDW[/MODEL]
Good luck. Please keep us posted with the results.
Thank you,
Simon.
Hi Simon,
On my oven, where would that be? (From what I’ve read, I thought that piece would be under the oven floor support, but I do see a piece that kind of looks like that in the top part.) And the weird thing is, it will Preheat during Convect Bake, just not on Regular Bake!
Thanks for your help!
