Oven won't light
My oven won’t light. The rod glows bright but the gas won’t start therefore the oven wont light. The top burners work fine, just the oven is not working.
Hi.
In order to open the gas valve the ignitor should have the amps draw of 3.2 Amp when it’s hot. You can check that with amp meter. (If you have one.)
If the amperage is less - replace the ignitor AP2020569
If it’s good - replace the safety gas valve AP2022762
Here are the breakdown diagrams and Replacement parts for General Electric RGB524PEA3WH Gas range | AppliancePartsPros.com
Thank you. Post the results.
Simon.
