Well, I was able to get the thermostat installed and I have some tips for the rest of you. On my particular oven rangetop there are 4 burners. When trying to figure out how to get the rangetop open, I discovered there are two clips in the front of the rangetop about 2 inches from each edge. I slipped a metal putty knife into the seam between the top and oven body and pushed firmly while lifting up the edge. After releasing both clips, I was able to raise the rangetop a few inches and prop it up using the small built-in wire stands.
Then I made the mistake of taking out the three Torx screws (T-15) holding in each of the burners (from the top). When I raised the range a little more, I noticed the burners were still attached by the igniters. This caused the gas lines to be pulled up and bent (they were easy to bend back, but it caused me some tense moments). The igniters seemed fragile and after a few attempts to remove them I gave up. Instead, I replaced the Torx screws and removed the ring nut from the center of each burner. I used a deep spark-plug socket and had no trouble.
Once the burners were all loose, I could gently raise the rangetop. I used a coat hanger to hold it up, attaching it though a burner opening and one of the vents in the back of the oven. Now I could see how the thermostat was installed. After pulling the knob straight off the front, I could see two screws holding it in. There was enough room to get them out without removing the whole metal control cover. After they were out, the thermostat pulled out easily and I was able to unplug both wires from it, making a note about which one went to which side.
The sensor wire was threaded between the burners and out the left side of the back of the oven. It went down through some fiberglass insulation, down a small hole and into the oven. I opened the oven door and located the fat end of the sensor wire. It was secured to the top rear of the oven by two stand-off clips. The clips can be compressed and removed from the oven wall, but that was unnecessary. I pushed the wire towards the back of the oven by placing my thumbs on either side of a clip, releasing it one clip at a time. Then I was able to pull the wire out so I could remove the old thermostat completely.
Since it was impossible to see the tiny hole from the top, I pulled the insulation to one side and then used the OLD thermostat sensor wire as an indicator. I pushed the fat end through the hole in the oven, and noted where it exited the insulation. I then lightly pushed the insulation around enough to see the hole, and removed the old wire. I then easily inserted the new thermostat wire in though the top, passed it through the clips and then pulled it gently toward me to snap it back properly into each clip. It should not wiggle once secured.
After that I just reversed the order and put it all back together. The ring nuts are easy to get started with your fingertips after you guide the rangetop back down onto the gas lines. I tested the thermostat and found it worked better than the original, being only a few degrees off the dial setting.
Thanks guys for great service and a great forum!
