Oven temp 100 degrees off
Brand:Kenmore
Model Number:79096197711
Main Symptom: oven temp 100 off
Error Code (if any): no code
Parts or tests already tried:I replace the temp probe now temp is stable at 100 off, temp was wild before
If the new oven sensor measures close to 1100 Ohms at room temperature, there would likely be an issue with the oven control board itself. 316630003 Range Oven Control Board | Genuine Frigidaire OEM In Stock
