Oven stopped working after self cleaning
after using the self clean feature we had a f5 e5 trouble code showing the oven clean temperture had not reached its maximum. we cleared that code and tried to use the bake feature and all we get is a lo reading and the oven doesn’t seem to work. the control panel seems to be ok, but after you set a temperture, instead of starting to heat the reading goes to lo.
Are you sure you tried to use Bake and not Broil? “Hi” or “Lo” usually displays for Broil temperature.
