Oven shuts off when try to use above 425 degrees
Brand:Whirlpool
Model Number: WFG320M0BS3
Main Symptom: Oven shuts of when try to use above 425 degrees also if use oven timer while oven is on it shuts off.
What happens & when: It turns off and the light starts blinking
If there is nothing that would be blocking the vent where it comes up under the console, the most likely cause of failure would be the main control. W11126814 Control Board (Blk) | Genuine Whirlpool OEM In Stock
