I turn my oven on and once it reaches temperature it shuts off and won’t go back on until it cools down. All the burners work fine. I have to keep turning it on just to cook a cake.
Most likely the problem is a bad control board (aka a clock). It has to be replaced together with the overlay which is glued to the clock.
[QUOTE=Gene;61368]Most likely the problem is a bad control board (aka a clock). It has to be replaced together with the overlay which is glued to the clock.
Gene.[/QUOTE]
Is this a hard part to replace. I just turned my oven on again today and I received an F1 error.
This error code proves that the clock has gone bad.
This part is not too difficult to replace yourself. Pull the range out of the wall and remove the rear panel.
I ordered the part and replaced it and my oven works great now! Thanks!
You are welcome. We are glad you were able to fix it.
