: We have a Jennair downdraft stove model jds9860aap. Thereis a problem with the oven. It shuts down on its own after it has been on forabout 30 mins. I have been able to take off the front panel and noticed a fan(probably for cooling) in the back top corner. In researching I discovered thata Hi-limit temperature switch controls this fan. I was able to pull the stoveout of its stall and set oven to 450 degrees. At approx 220 degrees I heardcooling fan run for about 10 seconds then quit. This happened at about every 30- 40 degree increase in temperature. Once oven reached the 450 degree mark,tone sounded that temperature was met. I only notice fan once for about another10 seconds then quit again. Oven will eventually shut itself down and restartonce it has cooled on its own. I am not sure if my problem lies with thisswitch or if the fan is faulty. Should this fan be running at longer intervals?
Hello. You will need to test and see if power is coming to the fan motor, when it is starting and stopping. If the power continues to come to the motor, and it starts and stops, you will need to replace the fan motor. You can test this with a multi-meter [AP3873826]. Here is a link on how to use a multi-meter. Hope this helps. http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/4810-how-check-continuity-ohmmeter.html
Thanks Jeff, tested motor disconnected from stove wire today with my digital meter set at 200. I got a 0.00 reading. I am ordering a new motor now.
Don
