Oven showing code F2
Performed an oven self clean and afterwards the fan would not shut off and the display shows a code F2. What is most likely trouble? Thanks
“F2” error code means a runaway temperature. Measure the oven sensor (#12 on the diagram) resistance which should be about 1100 Ohms at the room temperature. If there is nothing wrong then replace the relay board (#11 on the diagram).
  • The part number for the oven sensor is AP4009009
  • The part number for the relay board is AP4095668
Here are the breakdown diagrams and Replacement parts for JENN-AIR JMW9530AAW | AppliancePartsPros.com
