Oven Sensor Replacement
Not sure the age of the oven - could be older than 10 years, bought a new oven sensor because it doesn’t heat up all the way (thermometer says 200 when oven set to 350). Video instructions show to replace sensor from the back, but the oven is under the counter (not sure how to get it out of there) and it looks like the sensor is in the top of the oven and can be replaced from inside. Is that possible? It appears to screw into the back of the oven. Could I possibly replace from the inside? Thanks.
The oven sensor is shown as number 12 in the picture below. It is mounted from the back, through the oven wall. You will definitely need to access the sensor from the back of the oven.
I replaced the Oven Sensor on the Model Number: CWE9000BCE but according to an oven thermometer in the oven, the oven is still about 50 degrees off. I set the oven for 350. After 30 minutes, the oven thermometer still read 300. Assuming the thermometer is reliable, what is the next thing to check. Thanks.
