Oven repair
[FONT=Arial]Need help with a oven. Put new heating elements in and it still no t working.[/FONT]
I cannot find find any info on the given model number, please check it.
All the units I find have 3 letters at the end not 2.
If the stove top elements work OK and the wiring from/to the elements from the control board is OK then odds are that your control board is shot.
[quote=denman;798747]I cannot find find any info on the given model number, please check it.
If the stove top elements work OK and the wiring from/to the elements from the control board is OK then odds are that your control board is shot.[/quote]
The model number is FEFL79HBB
Parts for Frigidaire FEFL79HBB Range - AppliancePartsPros.com
Here is the wiring diagram
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316519936en.pdf
Yes it looks like your control board is bad (Item 20 in the Backguard Parts section)
You may also need a new overlay (part 20A) sometimes they do not come off without damaging the part.
Heating it up with a hair dryer often loosens it, just do not overheat it.
