KitchenAid, double convection oven: Bottom oven went on by itself – was told relay is bad need to replace electronics panel; also bottom element sparked when I tried to turn lower oven on and off – new element? Haven’t done this type of repair, parts are available – questions: instructions on opening top panel (accessing computer panel and replacing) – any help welcome; also access to bottom element? And replacing?
Okay, so the problem I was facing was the lower overn was going on by itself – KEBC208KSSO dual oven. I ordered and just replaced the electronics/computer board. Oven just came on again. Any thoughts out there?
