Oven Repair: Bake Element Needed
Brand: Whirlpool Oven
Model Number: RF4700XBW-2
Main Symptom: Broken Bake Element, OEM #W10674875
I need to replace a broken bake element in a Whirlpool Oven. The original part appears to be unavailable. Is there a part for a subsequent model of similar size, resistance, etc., that can be substituted for the original?
Regretfully as you say the element (Whirlpool W10674875 Range Elmnt-Bake | Genuine OEM Part) is no longer produced by the manufacturer and is not available in our system as an OEM part. At this point the only thing I can recommend is the aftermarket
Thanks for your response. I’ve tried every search I can think of; is there a special means of accessing aftermarket parts?
