PURCHASED OVEN AT SALVAGE, TOP OF OVEN HAS SMALL COVER PLATE ABOUT 3 " ACROSS MISSING. UNDER THIS, 2 WIRES ARE DANGLING (black & white). DON’T KNOW WHAT PART HAS BEEN REMOVED
I cannot find any info on this unit at AppliancePartsPros.
They probably have the parts but the model does not come up.
If you go to the Sears parts site it does come up so you should be able to find the part numbers there.
Below is a link to a MEMCW271ES.
I do not know how close a match it is to your unit but there may be some useful info in the manuals section.
Masterpiece Series 27 inch Combination Wall Oven MEMCW271ES - Stainless Steel
thanks will check
