Oven Outer Door Glass
Brand: Whirlpool
Model Number: WFE361LVS0
Main Symptom: broken glass (oven door)
What happens & when: I need help with my oven door, the outer glass broke last year, and I replaced it but now I see the glass is not sticking to the metal, I used 3M adhesive pads, and they are not working the way the supposed to. Should I replace the sticky pads? what pads should I use?
Usually you get new adhesive pads with the new glass. 3M tape won’t work as its not rated for high temp use. We do not offer the tape by itself but you can do an internet search for high temp double sided tape
