Oven not working
I am so thankful to have found this site! Hopefully, someone can advise me…
I have a gas, propane, stove is gas. All four top burners and broiler work, but the oven will not heat. I hear a click when I turn on/off the dial to set/turn off the oven.
And I might ad, I went to PC Richards, hoping that they could help me troubleshoot the problem, order the part and be on my merry way, but their advice was to buy a new stove and after I made it clear that was not an option, he stated I needed to make an appointment for a service call, but that is expensive too considering a service call would be $60, just to determine what part is needed, then another service call would be necessary to install. Please help :slight_smile:
Thank you so very much for your time ~
Lillian
Hello Lillian,
The model number you posted does not come up anywhere. Verify and repost it please.
How old is it?
Thank you for responding, Gene.
I apologize; according to the location guide on this site, I guided my roommate to the location last night, and this morning when I checked, I found another set of info located directly across from that area. Probably TMI…
The Model # is JGBP30BEW1WH, Serial # HS213766P. There is also a date on the plate of 1993 and listed with the another string of ID #'s is: ANSI: Z21.1 CGAIR58, 1995. I am not sure if that means it was made in 1993 or 1995.
I would greatly appreciate being able to use my stove again! This is only the second week without it, but as the saying goes, “You don’t know what you have until you lose it” :slight_smile:
Thank you for your time and expertise, Gene.
Lillian
You are welcome Lillian.
Remove the oven floor and watch the igniter while the control calls for Bake.
If the igniter does not glow, remove the igniter and check it for continuity.
If there is no continuity, replace the igniter.
If there is continuity, check for 120 VAC to the igniter while the control calls for Bake and post the results.
Here are the breakdown diagrams and Parts for GE JGBP30BEW1WH Range - AppliancePartsPros.com
Hi Gene,
Thank you once again for replying…
A friend of friend came over, I showed him your e-mail and he was able to troubleshoot it. Since the floor of the oven had rust spot, he gently tapped on the ignitor and thinking there might have been a build up on it too, and it ignited!
No part, no out of pocket! And I once again have use of my oven!!!
Again, thank you for your quick responses.
In His loving care,
Lillian~
Hi Lillian,
I’m glad to hear it was fixed but I’m afraid it would not last long. At least you know what to do if it will come back.
Good luck.
Yes, I will save your e-mail to troubleshoot, when it occurs again :slight_smile:
Thank you for all your time and expertise ~
In His loving care,
Lillian
