For some reason my oven isn’t working at all. I pulled and test the elements and they are good. What else could it be? The next thing I was going to try is getting the Eco board out.. I remember a pot boiling over once or twice that may have affected something in the board.. Seems like a hard job getting to it? Heeellpppppp
Hi.
Unfortunately I have limited access to the Canadian models.
But from the info was available most likely the problem is with open thermal circuit breaker.
On the wiring diagram it’s connected to the P4 (out) at the control board and then to the bake and broil elements as common wire.
Trace the wires and you will locate it. The part number should be on the breaker.
Good luck.
Simon.
