I live in a manufactured double wide and the oven/microwve oven are one unit. The microwave is working and the oven light is on but the oven will not work. could you give some ideas to check for some think.
What specifically will not work about it?? No display or lights or heat or just no heat??
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
The light in the oven works and the keypad for the microwave works but the keypad for the oven does not
The microwave unit, although it is in the same installation, is on a different circuit. First, check the breaker for the oven to see if it may be partially tripped.
The oven and microwave are on the same breaker we tripped them and it still does not work. My daughter said she turned it off and turned it back the other night to see if that is what it was.
I was assuming it was an electric range.
Iām afraid I can find no listing for such a model number to look up how it was designed. Can you double check it?
Dan O.
=D~~~~~~
That Is The Number In The Microwave Where Would It Be In The Oven. The Number Is Model # J Kp69w0w2ww Serial # Ts629170q
October 1997
The whole unit should only have one.
Thatās not what you initially supplied. It was jkp[SIZE=ā3ā]96[/SIZE]ā¦
None of itās buttons??
I canāt see there being any kind of fuse for just the ovenās control but someone could check the applianceās wiring diagram. Otherwise if all the buttons are not functioning there may be a problem in the regular ovenās control board or possibly the power transformer (see the following links) although the latter might be less suspect if it also powers the microwave control board. Again, someone would need to check the applianceās wiring diagram, I donāt have access to it.
LINK > GE JKP69W0W2WW Oven Control Board
LINK > GE JKP69W0W2WW Power Transformer
JMO
Dan O.
=D~~~~~~
