Oven not working
everything works but the oven 6 months old glass top the model numbers i have just dont click i just need to know is there a fuse block in this stove?
It will be a Canadian model so finding info is a pain.
There is not a fuse box in modern units.
If stove went out after a self clean, it is often a thermal cutout/fuse attached to the back or sometimes the top of the oven case on the outside.
I assume the stove top works correctly and is electric.
If it is a dual fuel could be you do not have 240 volts, sometimes you can loose half the line without actually tripping the breaker. Turn breaker off/on slowly a couple times.
Put in a service call and get it repaired under warranty.
If you open it up you could void your warranty also it could be something more expensive to repair like the electronic control board.
another canuck
