the oven will not heat up but the ignitor heats up perfectly and the burners work fine what do i check next
You will need to check your gas valve and make sure the ignitor is hot enough, it should be bright yellow.
Nat
Just to add my 2 cents…
You also should measure the current drawn by the igniter. If it is less than 3.2 amps then the igniter is bad and has to be replaced even if it glows.
- The part number for the oven igniter is [COLOR=#0066cc]AP205873[/COLOR]
