Needed to change bottom baking element. Was stupid and did not unplug it before I pulled out old element. Sparked Now entire oven and stove top does not work. What do I need to replace now?
Replacement parts for JBP78W0B1WW models | AppliancePartsPros.com
You can see that there is not a unit with a 0 between the W and B.
Since both the oven control and the stove top elements do not work, it sounds like a power problem.
The two are usually separate circuits in a stove.
So I would start by checking the power.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
[COLOR=“Red”]Be careful as 240 volts is lethal !!! [/COLOR]
If OK then unplug it and check that you have not burned off a wire that is common to oven and stove top (very few have one)
I cannot tell if the unit has an internal fuse. It is a GE and they like to keep everything a secret.
Do not be surprised if when you get the stove top working that the oven does not.
This usually blows the control board/timer.
