Brand: Bosch
Model Number: HGS8655UC/04
Main Symptom: Come staying lit
What happens & when: The burner will light but won’t stay lit. It is propane, there is plenty of propane, that’s not the issue.
My warranty ran out and I want to purchase all the parts that might be causing the issue and replace them, as it will likely cost less than getting the new warranty, and the unit isn’t working properly to get another/extend the warranty anyway.
With this model it could be several different things. I’m attaching the service manual for this model to help you in figuring out what it could be. The section about the oven not staying lit starts on page 23.
HGS8655UC_01 SM 58300000225445.pdf (2.3 MB)
It’s definitely the thermocoupler, however, I’m not seeing a part number for it anywhere in the service manual.
Would it be the same for HGS8655UC/04?
Yeah, I used that revision # when searching the part.
Thank you so much for your help! However, this isn’t a thermocouple. I have a faulty oven thermocouple.
Thank you, I just ordered the part.
