Whirlpool
WFE500M4HS
Oven not keeping temperature
Have to turn the temp way up (450-500) to get the oven to come on. Oven will heat up but won’t always maintain temperature. Curious what part is the likely culprit.
Whirlpool
WFE500M4HS
I found WFE500M4HS0
Both element work? Bake and Broil get red?
Oven door closes properly?
Both elements work, no loose wires and then the oven temp thermostat would be the prime suspect.
LINK> Oven Thermostat
jeff sr.
