Oven not holding consistent temperature
Brand: SAMSUNG
Model Number:NE58F9500SS/AA
Main Symptom: NOT HOLDING HEAT CONSISTENTLY
What happens & when: APPEARS TO LOSE TEMPERATURE DURING COOKING
Error Code (if any): NONE
Parts or tests already tried: TESTED ALL AREAS WITH MULTIMETER
OHMS SENSOR TEST = 1,075
BAKE MODE: (T501 & CN101) Input to Control Board = 242v / (T501 & T505) OUTPUT = 241v
BROIL (T501 & T503) = 241v
CONVECTION BAKE (T501 & T507) = 241v
BAKE ELEMENT BOTTOM: Started at 240v briefly and then went to Zero volts
BROIL ELEMENT = 240v
CONVECTION ELELMENT OHMS = 44.2
CONVECTION ELEMENT PLUGS = 240v *HOWEVER, clicking noise and ZERO voltage displayed, clicking noise again and back to 240v.
PLEASE HELP WITH ANY RECOMMENDATIONS
Test the oven sensor for the proper resistance, and check the wiring from the control to the elements for loose or broken connections. If all checks, then you would likely need a new control.
https://www.appliancepartspros.com/repair-help/
Oven sensor OHMS test was 44.2. All wires and connections look intact.
