Oven Not Heating...Please Help!
The baking and broil element do not heat at all. The clock/timer allows me to change settings,temperature,time, etc. I have done research by looking at schematics, and talked with appliance part employees,that were not able to help me. I have considered replacing both elements however have never used the broil element. Can you tell me what the problem might be,or what other parts may need to be replaced?
Thank you for taking the time to respond.
Replacement parts for TAP TEF326FBA | AppliancePartsPros.com
Throwing parts at it will just cost you extra dollars.
I am assuming all the surface elements and indicators operate correctly
If you do not have a meter see below.
Unplug the unit
Does the oven ready indicator say it is ready.
Could be that the temperature probe is shot. Check it unplugged also check it’s connector.
Here is a good link see Item 7
http://www.applianceaid.com/elecrange.html
Also could pull the bake element and check it for continuity.
Could also be the common wire for the bake and broil element has burned open.
If wires are good, temp probe good, elements are good, rest of stove runs correctly then all that is left is the control board.
I would suggest you purchase a meter. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
