My Kenmore slide in range displays a lock symbol in the display and nothing else. range top works fine…but the oven does not function. I tried unpluging the stove for a while to see if it would reset but no luck. The model number is canadian if that helps.
Thanks, Mike
I tried to post this very same problem but was unsuccessful. Did you get any response? I have been trying to figure out what is wrong. Thanks!
Linda
