Oven light will not go off
Brand:
Model Number:790.97503000
Main Symptom:Oven light will not go off.
What happens & when:I ordered a new door switch, order # 16778184. The new switch did not turn off the light, the light is on all the time. What do I do next?
With the light not turning off by the switch, this issue would most likely be caused by a control board. The light runs straight to the relay board and when the light remains on then it will be caused by a relay in the board that is stuck closed.
https://www.appliancepartspros.com/frigidaire-board-316443927-ap4373766.html
