Oven Light Cover
[COLOR=“Indigo”][SIZE=“3”][FONT=“Palatino Linotype”][/FONT][/SIZE][/COLOR]
I have a Kenmore oven Model 665. I do not know how to remove the oven light cover. Can you help?
Thank you in advance for any help on this subject.
Mrs. C.A. Robbins~Ostrosky
[quote=charlynrobbins@yahoo.com;460377]
Mrs. C.A. Robbins~Ostrosky[/quote]
Charlyn,
Could you get the complete model number(11 digits), so we can determine which light cover you have, and assist you correctly.
Thanks,
[COLOR=“Indigo”][/COLOR]
I have a Kenmore oven Model 665 and I am not sure how to remove the oven light cover to replace the light in the oven.
Thank you for getting back so quickly…I took the information off of the oven…
Model/ Stock No# Serial #
665 4433450 X03001854
I hope this is the information you need. Thank you again for your help with this.
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/245600-oven-light-cover.html#post460377#ixzz1OufFvp00
[quote=charlynrobbins@yahoo.com;460528]Thank you for getting back so quickly…I took the information off of the oven…
http://forum.appliancepartspros.com[/quote]
Charlyn,
AP7187174
It probably won’t be easy, due to age and heat, but , The glass lens can be removed by turning it counterclockwise, like the top of a jar.
Chances are, the lens has seized to the casing and won’t unscrew, like it should.
At that point, most techs would break the lens, clean up the glass and replace the bulb and lens.
The alternative turn power off the the range, slightly pull out and twist the assembly, until the spring loaded clips align with the “cut outs” in the oven wall, press down on the clips with a flatblade screwdriver, or simillar tool and tug on the assembly.
Remember to use a little vegetable oil on the threads of the lens, and don’t overtighten it when you install the new comonents.
Good Luck,
:cool: :cool: :cool:
