Brand:Whirlpool stove
Model Number:WFE770H0Z0
Main Symptom: not heating after replacing temperature sensor
Parts or tests already tried: replace d temperature sensor
Is it heating up at all? Does the oven error out? Does the seem to affecting bake and broil, or only bake?
No error out
Baking only- broiler works
I can set it to heat 350 reaches that temperature. Then I shut it off. Started back up again set it at 350 and it’s like it was never preheated to 350 the first time.
Bakerlady:
WFE770H0Z0
Can you see the bake element coming on during preheat?
I can feel the element getting warm- set at 400 show on panel LO
Check that bake element’s resistance value just to be safe, should be 10-40Ω, but this sounds like the control board W11308431.
https://www.appliancepartspros.com/whirlpool-cntrl-elec-w11308431-ap6832614.html
Where do I find the valve you mentioned
The element resistance reading or value, not valve.
Ok so where is this located. Do u have to take off the back panel of the stove to find the value
You need a multimeter and access to the element terminals behind the lower back panel of the range.
Ok that’s what I figured.
Question- my stove is 10 years old - do I replace it at this point.
We don’t offer opinions on whether or not an appliance is worth repairing, just repair advice.
Is a panel replacement a DIY
Yes, once you get the back off the console it is a very easy process.
Thank you for all your help.
If it is t the panel - can I return it??
