Oven inner glass replacement
We are in the process of replacing the interior glass on our oven door - location #3 - and are now trying to reassemble the door – we obviously didn’t pay enough attention to how the 2 interior pieces of glass were installed (locations 7 and 24) –
http://www.********************.com/ModelFrames.aspx?ModelID=804203&ModelNum=GBS307PDS11&mfgModelNum=&ManufactureID=3&Selected=8LXAIT7G&Position=2&mfg=Whirlpool&Type=&Mark=2
there only seems to be a place to secure one of them with a retainer –
Help, Please! :frowning:
This may help
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/7d69e72584ddde3385256a7e00524e76/$FILE/8178007.pdf
Here is the parts breakdown
Replacement parts for WHIRLPOOL GBS307PDS11 | AppliancePartsPros.com
Thank you so very much – the diagrams definitely help. Unfortunately, we broke one of the pieces of glass because we didn’t fasten them correctly before receiving your diagram, so as soon as the replacement comes - and we’ve put it back together - I’ll let you know how it went!
Everything went well - your diagrams did the trick - oven door is together and back in place! Thank you so much!
You guys are wonderful!! i had the same experience - didn’t pay enough attention when i took the door apart and then wasn’t sure how to reassemble it. the diagrams did the trick for me, too. thank you, thank you, thank you.
