Brand: frigidaire Model Number: fggh3047vfb Main Symptom: oven will not turn on What happens & when: the igniter doesn’t glow for bake cycle. I have replaced all parts in the circuit. I even verified that it’s not a frayed wire. I verified that the igniter works. I get no voltage on the relay board when the bake cycle is engaged. The broiler works.
Is it possible I was sent a defective relay board?
Error Code (if any): none
Parts or tests already tried: relay board and control panel, and igniter.
Yes, it’s possible you received a defective relay board, especially since you’ve already replaced the control panel, igniter, and relay board on your Frigidaire FGGH3047VFB. However, I’d like to verify one more thing before recommending another board.
The fact that the broiler works but the bake igniter never glows is an important clue. It tells us the oven has power and at least part of the control system is working.
Since you’ve confirmed the bake igniter is good, I’d concentrate on whether the relay board is receiving the command to turn on the bake circuit.
Here’s what I’d check next
1. Verify the voltage at the bake igniter. With Bake selected and the oven calling for heat, carefully measure AC voltage across the two igniter connections. You should normally see approximately 120 VAC when the bake circuit is energized.
2. Check the bake relay output. If there’s no voltage at the igniter, check the bake relay’s output on the board using the wiring diagram. If the board has proper power and receives the bake command but never switches power to the igniter, that points toward a defective relay board.
3. Check the wiring between the controls. Even though you’ve inspected the wires for damage, I’d also check continuity through the bake circuit and make sure the connectors are fully seated. A wire can look perfectly good but have a poor connection at a terminal.
Safety: These are live 120-volt tests. Use insulated probes and avoid touching exposed terminals. Disconnect power before performing continuity checks or moving connectors.
My recommendation
If you’ve confirmed the relay board has the proper incoming power, the bake command is reaching it, and there’s still no voltage leaving the bake relay, I’d strongly suspect the replacement board is defective.
I also found a previous repair discussion involving this exact model with very similar symptoms, so you’re not the only one who has encountered this problem.
AppliancePartsPros Forum
One question before you replace anything else:
When you say you’re getting no voltage at the relay board, are you measuring at the incoming power connection or at the bake relay’s output connection?
That distinction will help us determine whether the replacement board is defective or simply isn’t receiving the signal to activate Bake.
Thanks for uploading the service data sheet! I looked over the wiring diagram for your Frigidaire FGGH3047VFB, and I think we’re getting closer to finding the problem.
On page 1, you’ll see the relay board connections labeled L1, L2, L3, and J6. The diagram identifies J6 as the bake igniter output, and it also shows that the K1 double-line-break (DLB) relay is involved in the bake circuit.
Since your broiler works but the bake igniter isn’t receiving voltage, I’d start by verifying that the relay board has the proper incoming power.
First, with the power disconnected, locate the L1 terminal and the neutral connection using the wiring diagram on page 2. Then, if you’re comfortable making live-voltage measurements, restore power, set your multimeter to AC volts, and carefully measure between L1 and neutral. You should have approximately 120 volts AC, even when Bake isn’t selected. Be careful not to short adjacent terminals with your meter probes.
If you have 120 volts coming into the board, the next step is checking the bake circuit. When you select Bake and the oven calls for heat, you should have approximately 120 volts across the bake igniter circuit. If that voltage is missing, we need to determine whether the bake relay or the DLB relay isn’t closing, or whether the control isn’t commanding them to operate.
Because you’ve already replaced both the relay board and control panel, I wouldn’t purchase another part just yet. The fact that Broil works tells us that some of the control circuitry is functioning, but it doesn’t necessarily confirm that the bake circuit has everything it needs.
One question before we go further: When you measured zero volts at the bake relay output, where was your black multimeter probe connected? Was it on neutral, chassis ground, or the other side of the igniter circuit?
That will help me determine whether your original voltage reading was taken across the correct points and which connection we should check next. I’d like to rule out a power supply or wiring issue before we consider another defective relay board.
Thanks for the update. I can certainly understand your frustration, especially after replacing so many parts and still not having a working oven. The good news is that the igniters are now glowing, which tells us you’ve made some progress. I wouldn’t purchase any more parts until we make a couple of checks.
On your Frigidaire FGGH3047VFB, the oven uses a safety gas valve that depends on the igniter drawing enough electrical current before it will open and release gas.
Here’s what I’d check next.
1. Check how brightly the igniters glow. When you select Bake, does the bake igniter glow bright yellow-orange, or is it a dull red? An igniter can glow without drawing enough current to open the gas valve.
2. Check the igniter’s current draw. Using a clamp meter capable of measuring low AC amperage, a technician can measure the current through one igniter wire. Many flat-style oven igniters require approximately 3.2–3.6 amps to open the safety valve, although the correct specification depends on the installed igniter and valve. If the current is too low, the igniter or its circuit could still be the problem.
3. Verify the gas supply. Are the surface burners working normally? If they are, that confirms gas is reaching the range, but it doesn’t necessarily confirm gas is reaching the oven valve. Also, have the technician verify that the replacement gas valve is the correct part and that any oven gas shutoff is open.
4. Check the wiring connections. Since the thermostat and gas valve were replaced, I’d have the technician double-check the wiring at both components, along with the igniter connections. A loose connection or incorrect wiring could prevent the valve from opening.
One important caution: Don’t bypass the thermostat, jumper the gas valve, or attempt to manually release gas. Those components are part of the oven’s safety system.
A couple of questions:
When you select Bake, does the igniter glow continuously without lighting, or does it eventually shut off?
Do the surface burners work normally?
When you select Broil, does that igniter also glow without producing a flame?
The last question is particularly important. If both Bake and Broil igniters glow but neither burner lights, I’d be looking closely at the gas supply to the oven and the common wiring or safety-valve circuit before suspecting two bad igniters.
Since you’ve already invested so much in repairs, I would also ask the technician who diagnosed the thermostat and gas valve to return and verify the repair. At this point, you deserve a confirmed diagnosis rather than another round of replacing parts.
