We are having problems with our gas oven. First of all the broiler and the range work fine. The oven is another story. When we turn on the oven the glo light comes on. If the oven does actually come on it takes forever and we get a loud bang. The oven may come on and stay on or it may go off when it should come back on to re-heat up to a certain temperature. I have had two appliance men tell me two different parts that need to be replaced. One told me the oven igniter needs to be replaced and the other told me the gas valve. I don’t know who to believe or where to start. If the gas valve was bad would the range top and broiler still work properly? Any help you could give me would be greatly appreciated.
Nancy
