Brand:g e Model Number:pwb7030sl4ss Main Symptom:oven works microwave does not heat up What happens & when:timer on trun table moves no heat
Error Code (if any):none
Parts or tests already tried:none
Photos / video link:technician going to throw parts at it.diode capicitor transformer and magnitron without testing which part is the problem
If 120v AC has been verified at the low voltage side of the transformer when the microwave should be heating then one or more of the high voltage side components has failed. Often, one of those components failing causes others to as well.
It is only recommended for electricians and/or qualified technicians to test those high voltage components, and even then it can be dangerous due to the potential stored voltages involved.
