Brand:Whirlpool
Model Number:RBS305PRS00
Main Symptom:Shutooff
What happens & when:While oven is on an has preheated, the error code comes on and oven shuts-off. The door has locked on one occasion.
Error Code (if any):E2 F3
Based on the description and the error code, check sensor connection for loose or damaged connection, then measure sensor resistance (1080 Ω at 70° F)
If resistance is not valid, replace sensor. If sensor resistance and connections are good, then check for welded-closed relays on the control and replace as needed.
https://www.appliancepartspros.com/repair-help/
